Node Numbers along a Line
I'm trying to obtain the stress tensor along a straight line, I managed to obtain the stress tensor of all nodes, but I need to know the number of the nodes in order to extract the result. Is there a simpler way to do this? If possible, like a linearized stress, but instead of obtaining membrane, bending etc... I would like the componentes of the tensor SX SY SZ...
RE: Node Numbers along a Line
Maybe you will benefit from usage of path operations. But they will only produce plot of one component along predefined path.
For retreiving node numbers you can use *get comands:
generally
you select a line of interest
nsll, s
*get, node_count, node, 0, count
*dim, node_coord_s,array, node_count,7,
*do,i,1,node_count
*get, node_num, node, 0, num, min
node_coord_s(i,1)=node_num
node_coord_s(i,2)=NX(node_num)
node_coord_s(i,3)=NY(node_num)
node_coord_s(i,4)=NZ(node_num)
*GET, node_coord_s(i,5), NODE, node_num, s, x
*GET, node_coord_s(i,6), NODE, node_num, s, z
*GET, node_coord_s(i,7), NODE, node_num, s, z
nsel,u,node,,node_num
*enddo
Thanks for the answer. But unfortunately I did not quite understood it.
I have no experience with mechanical ADPL coding. I'm using Workbench Mechanical and don't know what to do with this code, I tried inserting it on the command prompt on the solution tab, but it did not returned me any results.
You should be able to add the coding from Stanum as a post-processing script in WB. If you still have trouble getting WB to do this, you can have it write out an input file that you could submit as a batch job in APDL. This would have the added advantage of allowing you to see inside the ANSYS black box and see how it works.
Thanks for the reply, I tried adding it as a command block on the solution tab, but It did not returned me anything. What can I be doing wrong?
What I want is to define a set of points , (x,y,z) and get the stress tensor for each point.
