Intersection lines not showing properly in Isometric view
NX 9.0
Please take a look at the attachment and see the difference between the model and the drawing. The lines where the fasteners intersect the block are not showing correctly in the drawing. I used to know how to fix this in NX 8.5 but can't seem to find the same setting in 9.0. Please help. Thank you!
Thank you,
Trent
NX 9.0.3.4
RE: Intersection lines not showing properly in Isometric view
Thank you,
Trent
NX 9.0.3.4
View -> settings -> common -> hidden lines -> process interfering solids.
www.nxjournaling.com
Thank you,
Trent
NX 9.0.3.4
Thank you,
Trent
NX 9.0.3.4
