Explosion, Oil, Oxygen
it is well said that oil mix with pure oxygen will have an explosion.
where the energy come from? it must be from the burning of the oil.
how can we calculate the intensity of the explosion?
for example, I have a device, may have .001 gram of oil inside an 0.1 cu in cavity. I charge it with 3,000 psi pure oxygen. how big a BOOM I will get?
thanks.
thanks.
RE: Explosion, Oil, Oxygen
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
I agree that it is the oil burning which provides the energy.
-Dalai Lama XIV
The pressurized pure oxygen ensures rapid, almost complete, combustion of the oil... hence maximum gas expansion in a very short period of time.
In a tightly confined space, the initial flame front would probably travels fast-enough in all directions at-once, to equate to a definition of detonation. Depending on the ammount of fuel and oxidizer and the size/strength/toughness of the containment vessel this detonation could be: (a) contained [pressure hiccup]; (b) uncontained
May find useful data in any of the following, available at DTIC http://www.dtic.mil/dtic/
AFAPL-TR-73-74 Fire and Explosion Manual for Aircraft Accident Investigators
AFWAL-TR-85-2057 Aircraft Mishap Fire Pattern Investigations
AFAPL-TR-79-2095 Dynamic, Hot-Surface Ignition of Aircraft Fuels and Hydraulic Fluids
Regards, Wil Taylor
o Trust - But Verify!
o We believe to be true what we prefer to be true.
o For those who believe, no proof is required; for those who cannot believe, no proof is possible.
o Unfortunately, in science what You 'believe' is irrelevant. ["Orion"]
o Learn the rules like a pro, so you can break them like an artist. [Picasso]
Mike Halloran
Pembroke Pines, FL, USA
Anything that is considered a "fuel source" is prohibited from oxygen/inner-wall-passage contact, such as most** oils [petroleum or synthetic], teflon, organic materials, cleaning solvent vapors, etc. The explosion [over-pressure breeching] of a fully pressurized O2-system can quickly turn catastropic.... worst yet is a component breech releasing a jet of pure oxygen into a area where where it was never intended to go. I can attest to the raw power of an O2-jet suddenly feeding a small fire on plastic. It rapidly expands the fire zone and will burn any fuel [fabrics, acrylic, aluminum, magnesium, titanium etc] within that zone at enormous intensity [another mishap investigation story].
**There are special inert lubricants [like Krytox] for use in O2 systems; otherwise everything is 100% dry assembly.
Regards, Wil Taylor
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
People have certainly seen a smoldering stick burst into flame when moved from atmospheric to an oxygen rich atmosphere.
At least it's not fluorine, which at STP is apparently energetic enough to ignite steel.
Looking interesting: http://www.astm.org/BOOKSTORE/STP_SERIES/OxyFlame.... Each is a collection of articles, which are available separately.
STP 1561 - Flammability and Sensitivity of Materials in Oxygen-Enriched Atmospheres: 13th Volume
STP 1522 - Flammability and Sensitivity of Materials in Oxygen-Enriched Atmospheres: 12th Volume
STP 1479 - Flammability and Sensitivity of Materials in Oxygen-Enriched Environments, 11th Volume
STP 1454 - Flammability and Sensitivity of Materials in Oxygen-Enriched Atmospheres: 10th Volume
STP 1395 - Flammability and Sensitivity of Materials in Oxygen-Enriched Atmospheres: 9th Volume
STP 1319 - Flammability and Sensitivity of Materials in Oxygen-Enriched Atmospheres: 8th Volume
STP 1267 - Flammability and Sensitivity of Materials in Oxygen-Enriched Atmospheres:7th Volume
STP 1197 - Flammability and Sensitivity of Materials n Oxygen-Enriched Atmospheres, Sixth Volume
STP 1111 - Flammability and Sensitivity of Materials in Oxygen-Enriched Atmospheres, 5th Volume
STP 1040 - Flammability and Sensitivity of Materials in Oxygen-Enriched Atmospheres
STP 986 - Flammability and Sensitivity of Materials in Oxygen-Enriched Atmospheres
STP 910 - Flammability and Sensitivity of Materials in Oxygen-Enriched Atmospheres
STP 812 - Flammability and Sensitivity of Materials in Oxygen-Enriched Atmospheres
However, charging that volume with 3000 psi air would result in something more on the order a rise of 118 degC, which, while hot, is not much of an explosion. There is something to be said for getting the right stoichiometry and pressure
TTFN
I installed an oxygen system on an aircraft and during the first pressurization , we found out the hard way that a thread lubricant had been used on a regulator. the resulting fire and over pressurization only lasted about 3 seconds, it just seemed longer. resulting in us having to strip out the entire installation and start over.
B.E.
You are judged not by what you know, but by what you can do.
http://avherald.com/h?article=44078aa7 Egyptair B777-200
Nothing that spectacular, With us it was just Pffft and a small flame launched into the center of the cockpit, from the back of the regulator.
It did not touch anything else, but the regulator and the line leading into it were literally toast.
B.E.
