3D VIEW IN DRAWING WITH ANNOTATIONS
is it possible to create iso view from 3d with annotations? i figured out how to create iso view from 3d but catia doesn't wont to grab annotations (dimensions). seems like it's only possible to grab dimensions in simple 2d views.
RE: 3D VIEW IN DRAWING WITH ANNOTATIONS
When you create a view from 3d you need need to select a view plane. For you to see the annotations you have to put the annotations in the view plane that you select for your view(see picture).
For the dimensions, I managed to put then in the same way as in a 2d view.
Hope it helps you,
Have a nice day.
not in simple 2d view. having axonometric view in 3d model doesn't seems to be so helpful.
