FMC pneumatic valve actuator help
Hi all, im new on here and looking for a bit of help/advice. Im trying to open up an actuator to check for damage but im not sure how to go about this. The actuator is fail closed and the bottom cover of the spring assembly has 4 bolts in it fitted with large thick washers. Ive removed these but the plate doesnt move. It looks as though there may be a ring/groove set up holding it in place. Can anyone offer any advice.
cheers Dave
cheers Dave
RE: FMC pneumatic valve actuator help
Valvit
Petrotrim Services, LLC
www.petrotrim.com
