Eccentricity in doing a lug-clevis analysis?
And is there a reference for this? I can't seem to find any references for this even though I know this is a criteria that is checked.
RE: Eccentricity in doing a lug-clevis analysis?
what sort of eccentricity are you thinking ok ?
Bruhn, section D , no good ??
Typically you need to check for a 10% misalignment transverse load on one lug, in combination with the tie rod axial load, if this is what you are looking for.
www.stressebook.com
Stressing Stresslessly!
