Adding to a Coomand in NX 8.5
Hi all I was wondering if it is possible to add commands to the hole command in modeling. For example our company has a standard size that we use for threaded inserts and dowel pins. So in theroy I would like to be able to go to the hole command and select "threaded insert" from the type drop down, and then select a part number and have the fields auto fill based on that selection. To do this do I need to go through the XML files that the hole command pulls from or do I need to have some special coding done?
RE: Adding to a Coomand in NX 8.5
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
