Possible to use a field in leader text fed from a table?
Hello!
I am set up a series of standard drawings for our shop rebar & stud spacing details. I use LT2014.
What I would like to accomplish is:
-Designer inputs stud spacing, and rebar spacing into a table (ex. '10M rebar @ 12" o/c')
-A leader in another part of the drawing has text associated through a field with that specific cell in the table, and automatically displays the text that is in the table cell
I haven't done much in the way of fields before, so if anyone can point me in the right direction it would be appreciated!
RE: Possible to use a field in leader text fed from a table?
Create a leader or mleader-
>Insert a field
>>In the Field Dialog, select Formula for the field name.
>>Then, select the Cell button, and pick the cell in the table you want to reference.
