Shear Stress in an I Beam
I am checking a beam for shear and am trying to decipher the code requirements for shear. .4FyA is the allowable stress, but the issue is with calculating the stress in the beam to compare to allowable.
For an I beam, I ignore the stress in the flanges and focus on the web. Taking the area of the web as DTw, I get the shear area. Divide the shear force by web area and the shear stress is found. Easy enough.
The mechanics of solids method for a rectangular cross section states that maximum shear stress is 1.5 V/A. My method computes average shear stress.
My question is which one is it appropriate to design an I beam using? The mechanics of solids method is more conservative, but usually shear isn't an issue.
RE: Shear Stress in an I Beam
Check your connection too, if a significant amount of web is removed or modified it's worth checking a net area.
Generally though unless it's short highly loaded beams, shear never governs in steel design.
As for addressing your specific, original question:
1) AISC allows you to use the average stress I believe.
2) I personally go with peak stresses (3/2 V_ave).
Using the average stress would seem to imply post-yield stress distribution. A "plastic shear capacity" of sorts. As long as your member doesn't have a constant shear diagram, I can see how that might be rationalized. However, the mechanics of that seem pretty complicated to me. Too complicated to justify any material savings that might accrue.
Thus, because we suppose full shear plastification, stress are indeed 'uniform' over the whole shear area...
I don't think about this often, so pardon my ignorance. Why wouldn't pure shear yield be sqrt(2)/2 of pure tension yield?
"It is imperative Cunth doesn't get his hands on those codes."
Never mind - I retract that question.
Fro a rectangular section (such as dimensional lumber or a plate), the maximum shear stress will be 1.5*(shear force)/(Area). This is a simplification of the same formula of (Shear Force * Q)/(I * Web Thickness).
BA
max shear stress in a rectangle is 1.5*(P/A), a result from VQ/It.
in an I beam the web shear stress (VQ/It) is much more constant, 'cause the flanges allow the ends of the webs to develop shear flow; so the average shear stress (P/A) is adequate for design. I'd expect that the "true" answer is that the web shear varies from 0.95 to 1.05*average.
In a previous thread here, it came to light that even the area of uncoped flanges can be included in the evaluation of the shear rupture capacity. Neat.
If I recall correctly, the AISC does discuss analysis at copes (in particular long copes). I do not have access to the code at the moment, but it was somewhere in the connections portion of the latest code. Perhaps others in this tread can elaborate if they have ready access to a copy of the code.
