Tube bending and pressure rating reduction?
Question: Does bending reduce pressure rating of 304/316 stainless steel tubing? Is there a way to estimate the extent of pressure rating reduction?
Case: 90 degree bending of 1/4" OD 1/8" ID 0.035" wall thickness, using a hand held bending tool (clamping die dia. 0.9")
Thanks.
Thanks.
RE: Tube bending and pressure rating reduction?
Workmanship is the key to maintaining roundness and maintaining the tube connections clean, square, and aligned.
Typically (for systems other than hydraulics with high pressure pulsation) tubing is rated based on some fraction of its burst strength. Usually 1/4 is used.
For high fatigue applications everything gets more complicated.
