sleeper support design
I want to design a simple cube shaped concrete sleeper support with embedded steel plate for pipe diameter 20".
It's a flow line and max. dead load is considered for hydro test.
The cube sizes are 1000x500x600depth with 12mm thick plate. No any axial stop considered.
Someone to confirm the design for standard pipe support.
