Do i need a structural engineers report to drill through 300ml reinforced concrete slab
please can someone tell me if ineed to get a structural engineers report to core drill through a 300ml reinforced concrete slab - it needs to be 110ml wide? Thanks
RE: Do i need a structural engineers report to drill through 300ml reinforced concrete slab
If the slab is PT, I would definitely consult a structural engineer prior to any drilling.
If the slab is CIP, probably not. Depends what the jurisdiction wants. However, I would still try to locate the reinforcing steel and miss it. Stay away from columns and the center of slab spans. Near the quarter of the spans would be a likely candidate area.
Mike McCann, PE, SE (WA)
mm = millimetre | ml = millilitre
Are you a structural engineer?
