Error "epsilon too small" when using DPM
Hi~
I am using ANSYS14 to simulate drop particle in a cylinder by DPM(Discrete Phase Model) and LES model(Large-Eddy-Simulation model).
The error "epsilon too small" appeared after 1.82 seconds, that is Flow time = 0.183s, time step = 183, which is as follows:
DPM Iteration ....
Internal error at line 16140 in file '..\..\src\dpm_path.c' on Node 1.
epsilon too small
Internal error at line 16140 in file '..\..\src\dpm_path.c' on Node 0.
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
number tracked = 1, escaped = 0, aborted = 0, trapped = 0, evaporated = 0, incomplete = 1, incomplete_parallel = 0
Parallel particle tracking concurrency: 33%
Can anyone kindly help?
Thank you!
DPM Iteration ....
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
epsilon too small
Thank you!
RE: Error "epsilon too small" when using DPM
In a while, I encountered an Error 10054 that said that the case can't run in a parallel way.
...Internal Error: ReadProcessMemory() failed MPI Application rank 2 exited before MPI_Finalize() with status 1 999999
(..\src\mpsystem.c@1173): mpt_read: failed: errno = 10054 999999: mpt_read: error: read failed trying to read 4 bytes: No such file or directory
It's solved after re-plugging the memory modules and re-read the license file.
