Minimum spacing of bars for crack control in reinforced concrete
Hi ,
I have a sump pit to be desigend absed on ACI Code , I figured flextural reinforcement , also checked the minimum spacing for cracks based on the stress in felxtural bars .
The minimum spacing of flextural bars are given in ACI 318 cl 10.6.4 ...
But can anyone tell me did i miss any criteria for minimum spacing of bars other than given above . Earlier times when i designed sump pit the minimum spacing of bars where restricted to 150 mm . I dont know the reason still. can anybody clarify me regarding this .
RE: Minimum spacing of bars for crack control in reinforced concrete
see this link as example, you may want to download pca concrete tank design. i think it's free.
http://civil.colorado.edu/~silverst/cven4830/Recta...
My standard sump detail shows the bars at 150 which I believe is an ACI350 thing. But then smaller pits use 6" walls which I believe is not compliant with ACI350. My take is that sump pits do not need to be waterproof. They just need to be durable in an often wet environment.
This could be accomplished with a wrap / WP membrane thought.
see quote from ACI 350 below with highlights
I was thinking it should be "maximum" also but decided to not be as pedantic as usual and let it slide!
