abaqus material removal by using mesh deletion
I have a part meshed and solved for residual stresses.
I d like to delete a layer of mesh to simulate material removal but keep the remaining residual stress values.
What should i do step by step?
Thanks in advance.
Thanks in advance.
RE: abaqus material removal by using mesh deletion
What i want is to get what remaining residual stresses are after material removal.
I will use that phase of the mesh with pretension applied and material removed for new loading conditions.
Thanks.
Have a look at the following link where they have an eroding projectile hitting an eroding plate.
Eroding projectile impacting eroding plate
Yes i want to simulate chip removed (like machined) by using mesh layer (same size with removed chip) deleted and get the remaining stress state.
It is not a chip removal problem but it is?
Thanks for your interest.
