Structural Framing Plan and Details
Hello all,
I am in the process of reviewing an existing structural framing plan with the hope of answering a constructibility question for an upcoming turnaround. My question to this forum is:
I appreciate your help in this matter.
-UBGrad
Why would a detailer call out the tension of select horizontal members on an elevation drawing of the framing plan? I have attached a PDF for your reference.
-UBGrad
RE: Structural Framing Plan and Details
When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.
-R. Buckminster Fuller
Look out for the tension in the connection of that horizontal leg of the large kneebrace in the upper left. You don't want to pry that connection off the column.
Why the WTs for bracing?
Although you are reviewing for constructability, you might mention to the designer that his design intent is apparently not clear to the shop drawing guy.
