changing custom config. specific
Hello ,
Is it possible to change the custom config. specific of a part WITHOUT opening the part?
for example with VBA
greetings mike
greetings mike
RE: changing custom config. specific
The only way I know to change doc. properties without opening the file it's using DSOfile (a M$ dll). But this can change only the doc. summary properties and the custom properties. Not the configuration specific (sad, isn't it?)
BBJT CSWP
Bradley
i will try the possibility
Greetings mike !!!
http://support.microsoft.com/default.aspx?scid=KB;en-us;q224351
