what end type is this
For the 1" manual ball valve class 600 st.st i found it written on the nameplate the ends are EB and i dont know what EB means? So i need help?
http://files.engineering.com/getfile.aspx?folder=3...
http://files.engineering.com/getfile.aspx?folder=a...
RE: what end type is this
I bet if you peel back some more insulation, you'll see the valve is butt weld end, and the weld is 6" (150 mm) or so from the valve body.
Valvit
maybe flange end
colin
EB = END BLOCK, decribing that the valve is a valve where different ends can be mounted (Fastened by screws) to the main body block,eg. for instance threaded or welded ends at different lengths and shapes etc???? (No general standard seems to cover the abbreviaation EB. The abbreviation EB has at least 611 different genereal meanings, listede in abbreviation lexicons).
