Stress Concentration Factor with FEM
Good Day All,
I need your advice on the following:
I am assessing a frame made mostly with H beams and braces with gusset plates connections. My client is asking to assess all the connections for fatigue, but I cannot find any typical stress concentration factor for H beams connections (beam to column web / beam to columns flange, butt connection etc) and pipes with gussets on regulations and standards. I am trying to determine the values through FEM analysis, but I would need some guidance on that. For the moment, I have tried to assess it through DNV Framework, but it gives me failure for fatigue even with SCF = 1. In that case, the typical connection would need to be redefined adding brackets or reviewing the shape etc. In that case, will the SCF of the revised connection be lower than 1 or in no case that can happen? DNV RP C203 gives the SCF only for the tubular joints or plated structures.
Many Thanks.
RE: Stress Concentration Factor with FEM
What does the frame support?
What kind of loading?
The frame is to be used offshore on a topside and supports equipment which are fixed. The fatigue loads are due to the environmental load only, hence vessel accelerations and prescribed displacement from ship bending.
Are you sure this condition doesn't fall under one of AISC's loading scenarios (see Appendix 3 of AISC 13th edition)?
I guess I misunderstood the calculation to be performed. I think if we use the DNV SN-Curves they should include already the SCF for the geometry and the allowable stress range should be compared to the nominal stress. Is that correct?
