AISC 13th Edition Equation F9-4
I have a project where the client needs to use a WT to resist wind loads. Therefore, these loads can act towards and away from the member. Using this equation and assuming the stem of the T will be in compression this equation ends up being negative. Is this correct?
RE: AISC 13th Edition Equation F9-4
