Internal coating for clarifier of juice (sugar mill)
hi to all
I have a question about that coating can be used for a clarifier tank of juice ( sugar mill ) ( fluid clarified juice ) (water , sugar, solid elements ) this fluid contains many suspended solids and usually the temperature is between 70 and 95 ° C is a food grade fluid so I wonder if they have any specification in mind.
currently lacks container coating and corrosion is high.
RE: Internal coating for clarifier of juice (sugar mill)
There are coatings sold for potable water tanks. Contact those vendors and ask their advice.
I don't know that sugar clarifiers are coated. In more modern mills, there are a lot of stainless steel vessels and equipment. Your best bet would be to contact a supplier of sugar mill equipment in your country.
thanks for you reply
I cannot change the vessel for stainless steel this is a old mills but i need to try solve the small problem, maybe in the future can change the vessel. the material of vessel is a carbon steel ASTM A36.
Was it ever coated? Is there a corrosion issue, or why do you want to coat it?
Why do not you contact me, we have many polyurea coatings, they are anticorossion and temperature resistance
