need a technical opinion
RE: need a technical opinion
I think the piece to which you refer is called a lintel.
It is definitely structural.
You need to hire a structural engineer to answer your question.
Mike Halloran
Pembroke Pines, FL, USA
It looks like a structural element to me. If you replace it with a steel beam, I expect that it will be working pretty hard.
The beam is carrying the floor above and a wall above. The depth of the concrete beam is probably the part that hangs down plus the depth of the floor system. If you replace it with a steel beam, that depth would be much less, so I wouldn't hold much hope of it working. But you really need to get a structural engineer to evaluate the situation to see if there is a practical solution.
Nobody has said this yet....but you need to get a structural engineer to look at this.... smile
JAE,
Mike beat you to it.
JAE...I'm shocked!lol
jakali...a steel beam that would carry the same load would likely not provide as much clearance as what you currently have....besides, the beam looks to be integrally cast with the section above it.
