Combined footing quick question,
Hi guys,
i was trying to design a combined footing, and i notice that the reaction that im getting due to seismic is positive in one column and negative in the other ( due to the direction of the siesmic, in reverse if the direction is changed). since they have a couple reaction due to siesmic sizing the footing is impossible i'll be getting trapezoidal in siesmic and if checked in static condition i'll be getting rectangular combined. i know that siesmic is instantaneous reaction and im thinking of using both the positive reaction from both the column irregardless of the direction. but i hope someone could in lighten me. i cant find a good sample dealing with siesmic combined footing.
thanks
thanks
RE: Combined footing quick question,
If you post some sketches showing the load cases that you're considering and how you're proposing to handle them, I'd be happy to provide comment.
thanks alot from your inputs, i tried to design the size of the combined footing considering static case and applying the said size to dynamic causing a great amount of eccentricity causing it to failing in the allowable bearing capacity even considering 130% increase in the allowable. Non the less i think i don't have any choice but to satisfy both static and dynamic.
thanks again,
