changing density for FGM in umat
Hello friends,
Here is the Abaqus user subroutine for Functionally Graded Material with direct integration method. This Umat is based on S.H.Song's Umat. Obviously the coefficient AAA in calculating E is the ratio of young moduli of two sides of the plate. With this method, one can change young modulus through the thickness.
But I have problem with changing density through the thickness, meaning from density of ceramic to density of metal.
I would be grateful if anyone can help me. Any help would be appreciated.
*USER SUBROUTINES
SUBROUTINE UMAT(STRESS,STATEV,DDSDDE,SSE,SPD,SCD,
1 RPL,DDSDDT,DRPLDE,DRPLDT,
2 STRAN,DSTRAN,TIME,DTIME,TEMP,DTEMP,PREDEF,DPRED,CMNAME,
3 NDI,NSHR,NTENS,NSTATEV,PROPS,NPROPS,COORDS,DROT,PNEWDT,
4 CELENT,DFGRD0,DFGRD1,NOEL,NPT,LAYER,KSPT,KSTEP,KINC)
C
INCLUDE 'ABA_PARAM.INC'
C
CHARACTER*80 CMNAME
DIMENSION STRESS(NTENS),STATEV(NSTATEV),
1 DDSDDE(NTENS,NTENS),DDSDDT(NTENS),DRPLDE(NTENS),
2 STRAN(NTENS),DSTRAN(NTENS),TIME(2),PREDEF(1),DPRED(1),
3 PROPS(NPROPS),COORDS(3),DROT(3,3),DFGRD0(3,3),DFGRD1(3,3)
C
PARAMETER (ONE=1.0D0, TWO=2.0D0)
C Determine material properties based on global coordinates of gauss points.
C COORDS(1) is X-coordinates of gauss points.
C COORDS(2) is Y-coordinates of gauss points.
C COORDS(3) is Z-coordinates of gauss points.
C PROPS is defined by users.
C The function can be also defined by users.
C
C------------- CHNGE -------------------------------------------------------------------------------C
C---------------------------------------------------------------------------------------------------C
E=PROPS(1)*EXP(AAA*COORDS(1))
V=PROPS(2)
C
C Determine Lame's constantes
C amu is mu
C alambeda is lambda
AMU=E/2.0d0/(1.0d0+V)
ALAMBDA=E*V/(1.0d0+V)/(1.0d0-2*V)
C
C
C Determine the tangant or Jacobian matrix
C
C NDI is number of normal stresses
C NSHR is number of shear stresses
C NTENS is dimension of constitutive matrix
C
C
DO I=1,NDI
DO J=1,NDI
if (I.eq.J) then
ddsdde(I,I)=ALAMBDA+2*AMU
else
ddsdde(I,J)=ALAMBDA
endif
ENDDO
ENDDO
DO I=NDI+1,NTENS
ddsdde(I,I)=AMU
ENDDO
C
C Determine the stress and update the stress
C
DO I=1,NTENS
DO J=1,NTENS
STRESS(I)=STRESS(I)+ddsdde(I,J)*DSTRAN(J)
ENDDO
ENDDO
C
RETURN
END
*USER SUBROUTINES
C
C
CHARACTER*80 CMNAME
C
C
V=PROPS(2)
C
C amu is mu
C
C
C
C
C
DO I=1,NDI
DO J=1,NDI
if (I.eq.J) then
else
ddsdde(I,J)=ALAMBDA
endif
ENDDO
ENDDO
DO I=NDI+1,NTENS
ddsdde(I,I)=AMU
ENDDO
C
C
DO I=1,NTENS
DO J=1,NTENS
ENDDO
ENDDO
C
RETURN
END
