API 653 & API650
API 653 & API650
Dear All,
Our API 650 Storage tank is already in service, Now client required to add one more nozzle on the shell side, So i just want to know what are things to be consider?? new nozzle will be maximum 4inch, Please advise me which standard i have to refer , API 653 is ok? because am new to this subject.
Thanks in Advance
Thanks in Advance
RE: API 653 & API650
Can you advice me few design consideration for this. The maximum nozzle size is 4", Location shell bottom course.
Nozzle size is 2" only on the shell side, I checked in the APi 653, i dint find the special consideration for this 2" nozzle. As per API 653 9.8.6 Insert plate shall be considered when the penetration larger than 2in NPS, Where as as per my case the nozzle size is only 2inch, So i think the insert plate & RF pad not required.
So please advise me any design consideration of requirement for install new 2" nozzle on the shell side.
Thanks in Advance
