CutExtrude issue- invalid sketch plane
Hi all,
I'm trying to create a full-scale truss for a static loading simulation using Abaqus.
I wanted to use a Python script to do this, but I am not very experienced with this language or the Abaqus methods.
The members forming the truss are cee sections. However, at the ends of the cee sections I want to create an extruded cut
like so:
[/URL]]Link
However, when I try to use the CutExtrude command, Abaqus keeps giving me an "Invalid sketch plane" error even though I'm sure that the face I'm putting in the CutExtrude method is correct.
Here is the picture of the cross section of my cee section
[/URL]]
Here are the co-ordinates I used to find the faces and the edges for the CutExtrude method
[URL=http://s1368.photobucket.com/user/victorc565/media...]
[/URL]
Here is my Python Code
from abaqus import *
from abaqusConstants import *
import regionToolset
session.viewports['Viewport: 1'].setValues(displayedObject=None)
#Create the model
mdb.models.changeKey(fromName='Model-1', toName='Malaysian Truss')
import sketch
import partition
import part
TrussModel = mdb.models['Malaysian Truss']
#Create the parts
#web member 1 of the truss assembly. Web members being the diagonal members between the top and bottom chord members of a truss
Web_cross_section_sketch= TrussModel.ConstrainedSketch(name='Member Cross Section', sheetSize=100)
d=100
b=60
l=20
length1=1600
Web_cross_section_sketch.Line(point1=(b/2,d/2-l), point2=(b/2,d/2))
Web_cross_section_sketch.Line(point1=(b/2,d/2), point2=(-b/2,d/2))
Web_cross_section_sketch.Line(point1=(-b/2,d/2), point2=(-b/2,-d/2))
Web_cross_section_sketch.Line(point1=(-b/2,-d/2), point2=(b/2,-d/2))
Web_cross_section_sketch.Line(point1=(b/2,-d/2), point2=(b/2,-d/2+l))
Truss_web_part_1=TrussModel.Part(name='Truss Web Member 1', dimensionality=THREE_D, type=DEFORMABLE_BODY)
Truss_web_part_1.BaseShellExtrude(sketch=Web_cross_section_sketch, depth= length1)
#web member 2
length2=1800
Truss_web_part_2=TrussModel.Part(name='Truss Web Member 2', dimensionality=THREE_D, type=DEFORMABLE_BODY)
Truss_web_part_2.BaseShellExtrude(sketch=Web_cross_section_sketch, depth= length2)
#apex gusset plate
Apex_gusset_sketch= TrussModel.ConstrainedSketch(name='Apex Gusset', sheetSize=100)
bapex=600
dapex= 100
hapex= 400
Apex_gusset_sketch.Line(point1=(-bapex/2,0), point2=(-bapex/2,dapex))
Apex_gusset_sketch.Line(point1=(-bapex/2,dapex), point2=(0,hapex))
Apex_gusset_sketch.Line(point1=(0,hapex), point2=(bapex/2,dapex))
Apex_gusset_sketch.Line(point1=(bapex/2,dapex), point2=(bapex/2,0))
Apex_gusset_sketch.Line(point1=(bapex/2,0), point2=(-bapex/2,0))
Truss_apex_gusset=TrussModel.Part(name='Apex Gusset', dimensionality=THREE_D, type=DEFORMABLE_BODY)
Truss_apex_gusset.BaseShell(sketch=Apex_gusset_sketch)
#Create the cuts at the end of the web members
cut_depth=40
cut_width=20
web_face_point_web=(-b/2,0,length1/2)
member_draw_edge_1_point=(-b/2,0,0)
web_face_1_web=Truss_web_part_1.faces.findAt((web_face_point_web,))
member_draw_edge_1=Truss_web_part_1.edges.findAt((member_draw_edge_1_point,))
Member_cut_transform=Truss_web_part_1.MakeSketchTransform(sketchPlane=web_face_1_web, sketchUpEdge=member_draw_edge_1,sketchPlaneSide=SIDE1, sketchOrientation=RIGHT,origin=(-b/2,0,length1/2))
Web_end_cut_sketch_TL=TrussModel.ConstrainedSketch(name='Member End Cut', sheetSize=100, transform=Member_cut_transform)
#Web_end_cut_sketch_TL.rectangle(point1=(0,0),point2=(10,10))
Web_end_cut_sketch_TL.Line(point1=(-length1/2,d/2),point2=(-length1/2+cut_depth,d/2))
Web_end_cut_sketch_TL.Line(point1=(-length1/2+cut_depth,d/2), point2=(-length1/2,d/2-cut_width))
Web_end_cut_sketch_TL.Line(point1=(-length1/2,d/2-cut_width), point2=(-length1/2,d/2))
Truss_web_part_1.CutExtrude(sketchPlane=web_face_1_web, sketchUpEdge=member_draw_edge_1,sketchOrientation=RIGHT, sketchPlaneSide=SIDE1, sketch=Web_end_cut_sketch_TL)
Any help that you could provide with this issue would be greatly appreciated.
thank you very much,
Victor
like so:
[/URL]]LinkHowever, when I try to use the CutExtrude command, Abaqus keeps giving me an "Invalid sketch plane" error even though I'm sure that the face I'm putting in the CutExtrude method is correct.
[/URL]]Here are the co-ordinates I used to find the faces and the edges for the CutExtrude method
[/URL]Here is my Python Code
#Create the model
import sketch
import partition
import part
#Create the parts
d=100
b=60
l=20
length1=1600
#web member 2
length2=1800
#apex gusset plate
bapex=600
dapex= 100
hapex= 400
cut_depth=40
cut_width=20
Victor
