Boiler Efficiency
Boiler Efficiency
Boiler Efficiency
Hi there,
Can anyone help to clarify the boiler efficiency calculation particularly on the output part?
Control Volume is only on the boiler
Example: Assuming that there is no blowdown,
Mass balance:
Mass of feedwater = mass of steam
Energy Balance:
Mass of feedwater X Feedwater enthalpy = Mass of steam X Steam enthalpy
So the output on boiler efficiency equation would be:
Mass of steam X Steam enthalpy - Mass of FW X FW enthalpy
Replacing mass of FW to mass of steam would give us
Mass of steam (Steam enthalpy - FW enthalpy)
Now usually have blowdown to remove impurities
Looking at the same control volume with blowdown would give the following equations:
Mass balance:
Mass of FW = mass of steam + mass of blowdown
Energy Balance:
Mass of FW X FW enthalpy = mass of steam X steam enthalpy + mass of blowdown X blowdown enthalpy
Then the output on the boiler efficiency would be:
Mass of blowdown X blowdown enthalpy + mass of steam X Steam enthalpy - Mass of FW X FW enthalpy
Replacing of Mass of FW would give
Mass of BD X BD enthalpy + mass of steam X Steam enthalpy - mass of steam X FW enthalpy - mass of BD X FW enthalpy
or
Mass of Steam ( Steam enthalpy - FW enthlapy) + Mass of Blowdown (Steam enthalpy - FW enthalpy)
Am I doing it right?
Sorry for the long equations. Hope you guys can understand what I'm trying to ask.
RE: Boiler Efficiency
I would suggest you read the power test code ASME PTC 4.1 to get a better idea of how boiler efficiency is calculated, or read the book "Steam" by B&W , in particulate the chapter on combustion and boiler efficiency.
"Whom the gods would destroy, they first make mad "
Your energy balance equations should include heat input eg
Mass of feedwater X Feedwater enthalpy + Heat Input = Mass of steam X Steam enthalpy
je suis charlie
