ZIP UGNX ASSEMBLY
ZIP UGNX ASSEMBLY
ZIP UGNX ASSEMBLY
I run NX9 on WIN7 Pro 64bit and I have the issue, receive the error message. command not working,
Can any one having setup for UG Zip Components utility for nx9?
If any one please share.
Thanks In advance.
Devidas
RE: ZIP UGNX ASSEMBLY
This thread should help:
http://www.eng-tips.com/viewthread.cfm?qid=345894
But in case the downloads are no longer active, I've attached copies of the current files. After downloading the item and before you attempt to extract the files, edit the file extension from .zipper to .zip. You should find everything you need to get set-up and running.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I have ugzipc.men in my startup folder, configured as ...
VERSION 130
! This script will insert UGZipC in the File->Export menu
! To be placed in your startup-directory
EDIT UG_GATEWAY_MAIN_MENUBAR
BEFORE UG_FILE_QUIT
BUTTON UGZIPC_BTTN
LABEL Zip Assembly...
ACTIONS ugzipc_win64.dll
SEPARATOR
END_OF_BEFORE
NX 9.0.3.4
NX 10 (Testing)
Windows 7 64 (Windows 8.1 Tablet)
