GD&T (or other) callout
Hello All,
Take a look at the attachment. I have hundreds of these pillars that will be positioned and adjusted using studs with leveling nuts.
I need the red face of the pillars to all lay in the same plane as one another within 1/32" of an inch. (We usually do this by just projecting out a laser line).
The other important feature is that the red pads set a certain distance DOWN from the blue face. But the blue face will probably be very sloppy (+/- 1/2" or so).
I know my attempt isn't right here because the other plates can be out of plane but still meet parallelism.
How can I best describe my intent?
-Kevin
RE: GD&T (or other) callout
