ASME BPVC Section VIII Division 1 UG-34
Hey there,
I am currently analyzing a vessel that uses an unstayed flat head that is bolted down with thirty two 1-1/8-8 bolts. The gasket is a full-face typed elastomer gasket that follows sketch (p) of Fig. UG-34. Generally, Appendix 2 is used to carry out calculations for the bolts and the flange or cover, but in the first line of Appendix 2 it states it can only be used when the gasket material is contained completely within the bolt diameter. Seeing that this vessel utilizes a full-face gasket that has bolt holes machined out it, Appendix 2 can't be used.
I know that I can use equation 1 in UG-34 to calculate the thickness of the flat head, but how should I go about calculating bolt stresses and the required thickness of the flat head because of the compression stress of the bolts? Is there a standard I can reference or do I need to use FEA or some textbook equations?
David
David
RE: ASME BPVC Section VIII Division 1 UG-34
Try this DS/CEN/TR 1591-5. I have not used this myself yet but know such thing exists.
Also, is my assumption about not being able to use Appendix 2 correct?
Examination of the relevant UG-34 equation will reveal that the bolting is of no interest in calculating the head required thickness.
You can actually use Appendix 2 methods to establish the required bolting, if taking proper account of gasket geometry, etc.
Mike
Mike
I am aware that that much of pressure vessel design was completed way before the days of FEA.
I am just curious about the effects of overbolting on the flange and cover thickness. The vessel that I am analyzing is a 20 psi vessel that has 32 bolts on a 33.38" diameter. The spacing is definitely more than adequate, but I am trying to understand the effects of what could happen if someone fully torqued all 32 of the 1 inch bolts. I know in appendix 2 they size the flange based on the pressure load and the gasket load, which takes into account the total force that can be applied by the bolts onto the flange.
Also, thank you for trying to upload that bulletin!
David
You will find an old, poor copy of Bullletin #45 attached, maybe you can locate a better one. A discussion and calc form for this is also included in TF Bulletin #502.
Mike
Does that being true eliminate the need to consider bolting because there is effectively no bending of the cover or flange occurring?
This assumes that the gasket is the same width from bolt circle to OD and bolt circle to ID.
See Bulletin #45 for a more general treatment.
Mike
If the gasket has twice the width inside the bolts than that outside the bolts, then I could definitely see how the equivalent location of gasket reaction would be inside of the bolt holes by a small amount. I found a book that deals with this very topic.
David
Any suggested alternates to Engineering.com?
Mike
Enjoy,
Mike
David
Mike
Is the fact that tr can be less than UG-16 minimum (which makes perfect sense, because the reinforcement area required is dependent on the actual loading) stated anywhere in the code book? Or is that just common sense?
I am asking because I am acting as a third party reviewing calcs that were already completed. It would be nice to point to a specific article that justifies the above statement. Generally, using a higher tr increases the Areq, which means the original calculation could be considered "more conservative" because the area available still met that higher Areq.
Thanks again,
David
DMay121, I doubt you are going to find it written in the Code. I frankly don't believe I have run into a situation where tr has been so small that UG-16 thickness is a consideration, not that it couldn't happen. As well, re-reading UG-16, it would appear to not apply to nozzles, where trn below UG-16 thickness could be more commom.
Common sense? I dunno. Common practice? I'd say yeah.
Of course, if tr is set at UG-16 thickness and reinforcement makes without adverse economical effects on the design, I suppose the practice is not wrong. I'm thinking of a situation where, say, shell / head thickness is 1/4", tr is 0.050", tr is then set to 0.063" and reinforcement is adequate. No harm in a little extra conservatism.
This is the kind of thing that makes checking / reviewing other's work such a joy. I have myself found it necessary to adopt the philosophy "If it ain't wrong, it's right."
Good luck,
Mike
