NX9 CAM - Different feed rates in G code
Hey all,
I am currently exploring NXCAM and I have a small discrepancy between my setup and the G generated code.
Example: Spot drill operation, tool diameter=3.15mm, surface speed=35m/s, feed per tooth=0.125mm, 2 teeth, sprindle speed=3537rpm, cut feed rate=884.25mm/min.
Now in the post-processed G code, the drilling cycle is initiated with N0060 G82 Z-.9449 R-1.1024 F34.8 M08.
I don't see any relationship between the parameters of my operation and the feed rate in the code. Can anyonehelp me along here?
Thanks a lot!
Thanks a lot!
RE: NX9 CAM - Different feed rates in G code
884.25mm/25.4=34.8in
Ben Loosli
Floor milling, tool diameter=116mm, surface speed=110m/s, feed per tooth=0.05mm, 4 teeth, sprindle speed=302rpm, cut feed rate=60.4mm/min.
In the G code, I get a feed rate of 90.6, which is a totally different ratio that the feed rates in the first example...
Can you post an example of the code?
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX7.5, NX9.0, NX10.0(Testing)
Vericut7.3.3
