I need some help
I need some help
I need some help
hi! folks i think that this thread woudnt be here but i couldnt find any other forum for some help about an issue i am looking for
So let me introduce myself, my name is Juan Emilio and i am an electrical engineer from Argentina with experience in high voltage, high power engineering industry here. I have worked with synchronous generators and motor in the hundreds of megawatts, i have also worked with power transformers (800 MVA, 500kV) and also in a high voltage laboratory in a hight voltage insulator factory.
So my questions is, where could i find a list of american companies according with that kind of technology?
i look forward to hearing from you
Thank you
Juan
RE: I need some help
Weird. I would have thought that forum237: Electric motors, generators & controls engineering or forum238: Electric power & transmission & distribution would extremely applicable. If so, you should hit that "Red flag this post" link at the bottom of each posting to ask the moderator to delete this particular thread and re-post in one of the cited forums
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
You really should ask site management to change the name of your thread. You probably saw the admonition against using "Help" as your subject. "I need help" pretty close to that and many people refuse to open threads without a meaningful title. Site management will change it for you if you hit the "Red Flag" button and ask them to.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
