Coplanar Problems with AutoCAD 14
I have been having a lot of problems with filleting objects on a drawing I'm working on. I draw a line and then I draw another one perpendicular to the first. When I try to use the fillet command on them I get the error message “Lines are non coplanar.” I have gone thru the help files with little luck. Usually I can figure stuff out but I can’t seem to get this one fixed. Is there a variable that will keep this from happening – I know that it is only certain drawings I have problems with. Any help that anyone can provide would be great!
Thanks so much :)
Thanks so much :)
RE: Coplanar Problems with AutoCAD 14
I find that this problem usually occurs when I am using osnap while drawing. Remember that osnap will snap to all three coordinates of the selected point. As a civil engineer, this usually happens to me when working with topographic files generated from flown aerials. All the entities in the drawing usually have seperate elevations, and using osnap results in linework that is not in the 2-D drawing plane, causing problems with commands like fillet, extend, and trim.
You can avoid this by using point filters with your osnap command, and specifying the z-coordinate that you are really after.
The problem is that you are working w/ a 3-D line. It often happens if you have set a "Z-cooridinate" point and have snapped to it, etc. To do your filleting first check the properties of your line. You will probably find a "Z-coordinate" of something other than 0. Change both sets of coordinate end points to have a "Z" value of 0. Then make sure the line you are trying to connect has a z-coord of 0 also. You should then be able to fillet.
Hope this helps.
