I can't run the assembly with "The assembly environment cannot be activated "
I can't run the assembly with "The assembly environment cannot be activated " after teamcenter(SEEC) install.
part modeling is ok.
I use ST5.
How can I fix this problem.
RE: I can't run the assembly with "The assembly environment cannot be activated "
Perhaps you could try deleting the following from your registry:
hkey_current_user\software\unigraphics solutions\solid edge
Export the registry entry first as a backup. The next time you start SE this registry entry will be recreated. It might solve your problem. Or it might not. But it's often a basic first attempt.
