Crushed Concrete Used as Soil Stabilization?
Has any one had experience with crushed concrete being used for soil stabilization? The contractor is hogging out soupy muck from an 8' wide sanitary sewer trench. We are requiring the contractor to place 6-12" rock and apply pressure until the rock cannot go any deeper (so far it has been about 2'). The contractor asked if they could use recycled concrete. I have not heard of recycled concrete being used for stabilization.
I like the idea of using recycled material but I am concerned that when pressure is applied to push the recycled concrete into the muck it will crumble and we will not have the size rock we were wanting. Furthermore, should I be concerned about the admixtures in the concrete, fly ash, calcined clay, silica fume, etc?
Thank you for your opinions.
RE: Crushed Concrete Used as Soil Stabilization?
If rebar is left in the chunks, it needs to be short sections only.
Richard A. Cornelius, P.E.
WWW.amlinereast.com
Doug Hole
Junior Geotechnical Engineer
