Primary fuse for VT
Primary fuse for VT
Is it recommended to protect Voltage transformer by Primary fuses?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Primary fuse for VT
99NEC450-3(c) Voltage transformers installed indoors or enclosed shall be protected with primary fuses.
The transformer must be protected on the primary side (though it need not be on the secondary side)either by a fuse or a circuit breaker. The modern practice is to use a circuit breakers for units 1MVA and above.
It is not mandatory (as per IEC anyway)to have a fuse on the primary side on VT if the VT is of a cast resin type design and located in a fault free deemed zone and some switchgear manufacturers have adopted this practice. The secondary side is fused in the usual manner.
Mnufacturers who have a oil filled (often withdrawable ) design would offer a fused primary design.
Therefore it is more of a question of choice.
For HV, primary protection gets a lot more expensive and you will almost always have instantaneous bus protection. Generally, I would not provide primary fusing on HV VT's.
Thanks for your expert comments.
HiSet
