[FEMAP API] Nastran ModelCheck Options
I'm writing a simple .bas file that does a Modal FreeFree analysis automatically. The problem is that I'm not able to print groundcheck results in the .f06 file.
In the code I've put the requests (taken by API guide)
feMod.NasMCheckOn = True
feMod.NasMCheckGrndDOFSet(0) = true
feMod.NasMCheckGrndDOFSet(1) = true
feMod.NasMCheckGrndDOFSet(2) = true
feMod.NasMCheckGrndDOFSet(3) = true
feMod.NasMCheckGrndDOFSet(4) = true
but they doesn't appear in the .f06 file.
If I read .dat/.bdf file indeed there isn't the voice GROUNDCHECK(SET=ALL)=YES, or similar, before the BEGIN BULK card.
I've tried to modifiy "Destination" property to Print, Print+Post etc but not solve the problem
Anyone has done something similar? Any help would be much appreciated.
Thank in advice.
Crostolo
Thank in advice.
Crostolo
RE: [FEMAP API] Nastran ModelCheck Options
It looks to me though, that you may not be committing the data to the database. Remember that when you create an entity object, it only exists in memory, and any changes you make to it, must be committed back to the database in order to have an effect on your model. The following code works for what you're trying to do:
Sub Main Dim App As femap.model Set App = feFemap() Dim fam As femap.AnalysisMgr Set fam = App.feAnalysisMgr fam.Get( 1 ) fam.NasMCheckOn = True fam.NasMCheckGrndDOFSet( 0 ) = True fam.NasMCheckGrndDOFSet( 1 ) = True fam.NasMCheckGrndDOFSet( 2 ) = True fam.NasMCheckGrndDOFSet( 3 ) = True fam.NasMCheckGrndDOFSet( 4 ) = True fam.Put( fam.ID ) End SubIn the line "fam.Get( 1 )", replace the value 1 with the ID of your output set.
<snip> ECHO = NONE GROUNDCHECK(PRINT,SET=(G,N,N+AUTOSPC,F,A), DATAREC=NO)=YES DISPLACEMENT(PLOT) = ALL </snip>Regards,
Patrick
thanks for your answer.
The "problem" unfortunately still persist. If I open the analysis manager to see if GROUNDCHECK is being written in MODELCHECK portion of the analysis made only by API I see all the checkmarks in the right position. Indeed if I launch manually that analysis the .bdf is written correctly.
I try to figure out what is the problem
In the complete API file I also call the Nastran Executive Control Object, to modify number of CPUs used, save folder etc...
I noticed to use GROUNDCHECK you have to specify also the version of the executive control so
fam.NAsExecOn = True
fam.NasExecVersion = 2001
Hope this will be helpful in the future for someone who approach femap API programming.
