NX (9) on 32" Screen (failure)
does anyone has a solution for following (graphic) problem in NX9 on a 32" screen.
When I use MB1-2-3 (also in combination wth ctrl+shft) in the graphic window, the menu/radial pop-up, pops up 5 cm next to the mouse pointer.
I've tried to solve the problem by updating graphic driver, but that wasn't the solution.
Any Ideas ?
Thanks in advance.
Fred
Freelance 3D ENGINEER
www.f-dh.be
RE: NX (9) on 32" Screen (failure)
Certified Graphics adapter ?
- Nvidia Quadro ?
Tomas
yes, Nvidia Quadro K4000
driver : 340.66
www.f-dh.be
Thats strange, i have run NX on a 60" Sharp Aquos ( TV set /Monitor) without seeing anything similar.
I run a Quadro 4000M ( Laptop) , driver 341.05
- Call GTAC.
Tomas
The problem has been solved.
I had to change the properties of the NX startup command.
In the compability tab - settings - enable modify screen while using high DPI settings
BR
www.f-dh.be
