Vismockup clearance results filter
we use Vismockup to generate clearance checks and I have a question regarding the results.
When the check is started there are usually many false errors which are not relevant for example bolts.
In Vismockup the status of the error can be switched to not relevant but I cannot find the filter which then filters out the relevant results.
Does anybody know how to do this or if there is another way?
Tanks
Klaus
Tanks
Klaus
Unigraphics Key user
V13, V14, V15, V16, V17, V18, NX, NX2, NX3, NX4, NX5, NX6, NX7.5, NX8, NX8.5, NX9
