Part File Closes from All open Assembly Session - NX 9.0.3.4
I open a Assemble 'A' having 3 components,say '1,2,3'.
Also I open one of the part,say'3' using File>Open and Closes it.
It closes the component '3' from the Assemble 'A'.If I don't want this behavior,what needs to be done?
Kindly let me know if there is any setting needs to be set?
Mathi K
Mathi K
RE: Part File Closes from All open Assembly Session - NX 9.0.3.4
"Component 3" and "File 3" is the same thing.
"File 3" is shown in the assembly and by then we call it "component 3".
There is NO copy of the data from "file 3" to the assembly by default, it is "File 3" which is shown / seen in the assembly.
If you close "file 3" you have closed file 3 which is = component 3.
Do not close file 3 if you want to still see component 3 in your assembly.
It is that simple.
Tomas
