Reuse Library - Create Pocker
Hi there,
Anybody have problems with minor bolts in NX 9.0 - creating pockets?
In NX8.5 everything works fine, I can create automatic substract by adding bolts with creating pocket option, but in NX9.0 there is an error message with info "Failed to create for the reusable component". Its only happens with adding minor bolts like M1.6 ; M2 ; etc till M4. After when I type M4 hex bolt DIN standard everthing works fine.
Is this related with internal NX9.0 Reuse library settings?
For example I paste some attachments to request.
Best regards,
