Low Shear Valve .
Low Shear Valve .
Hi all,
I am working on a oil and Gas project, Customer has requested to offer a Low shear valve for Oil+Water service. But in the data sheet it is mentioned Globe valve. As per my Experience it should be to prevent Emulsification. but i have no idea about the trims used for this service. Can some one suggest me wat type of valve to choose? (Eccentric plug, Axial valve,Globe valve)?
Elango
Dubai
+971558373009
Elango
Dubai
+971558373009
RE: Low Shear Valve .
As pressure drop across a valve increases, more tight emulsion is created between hydrocarbon and aqueous phase. These valves offer "more gentle" pressure drop, apparently through a cyclonic design consisting of multiple tangential orifices and a venturi-shaped discharge. See also http://etc14.ens-lyon.fr/openconf/modules/request.... and http://www.typhonix.com/technology-and-products/ty...
Dejan IVANOVIC
Process Engineer, MSChE
