abaqus charpy impact
The elements in element set WarnElemFailElemInContact are part of a deformable surface that is referenced by a *CONTACT PAIR option in addition to having material properties that allow the element to fail. For elements that can fail, contact should be defined using the *CONTACT option.
i'm doing the Charpy impact test and added ductile damage in material section cause the errror above occurs. can someone help me with this problem ?
