I want to start studying selection of manual valves and flow criteria inside valves?
I want to start studying selection of manual valves and flow criteria inside valves, so I need a guidance like some books or softawre for fluid simulation?
RE: I want to start studying selection of manual valves and flow criteria inside valves?
You can start with these classic references:
P.SKOUSEN - Valve Handbook
R.ZAPPE - Valve Selection Handbook
Crane TP 410 - Flow of Fluids Through Valves, Fittings, and Pipe
For evaluating different control valve designs, download free copy of Fisher Specification Manager at: http://www2.emersonprocess.com/en-us/brands/fisher...
Dejan IVANOVIC
Process Engineer, MSChE
In addition: Use the net actively. Search this forum and the net generally (especially for suppliers and producerssuppliers information) both for specific questions and general selection. Many larger well-renownn producers have updated selection guides depending on flow, media and detailed flow characteristics.
Remember that the situation seldom is static over a longer perode in a valve: it will always vary and be dependent on what you let in and take out of your system, and what happens elswehere in the system.
Good luck!
IVANOVIC YOU ARE THE ONE WHO ALWAYS HELPS ME THANKS ALOT
Hi Mostafa,
Everybody helps a lot here. Just the very fact that all these people take their time to read posts and type answers, is an effort which should be appreciated. Depending how detailed is your question and how much input data is provided, you are likely to receive more and good quality answers.
Dejan IVANOVIC
Hi EmmanuelTop,
yes you are right, i just wanted to thank you as you replied me in more than post & a thanks for every body who tries to help here :) :).
