NX 9 Using Reference Parts
I'm re-creating parts using reference parts in NX 9. All was going well until I hid the reference part and then it automatically hid the new part I created. Is there any way to overcome this?
RE: NX 9 Using Reference Parts
Are you creating new geometry in the same file as the reference part?
Are you adding the reference part as a component to the new part?
Are you referencing geometry from the ref part (wave linking) to the new part?
www.nxjournaling.com
You can now link geometry from compA into the part file of compB.
Is this the type of assembly structure you have? Now when you hide compA, compB is hidden as well?
Also if you can, try to take cowski advice on assemblies with multiple components.
