Open the Part file through batch
Hi All,
Is there any option to open the part file through batch using command line argument.
Generally applications accepts the command line arguments. I tried in NX but it is not working.
For example:
call %UGII_ROOT_DIR%\ugraf.exe D:\files\testPart.prt
Selvaraj C
NX Automation Engineer
For example:
Selvaraj C
RE: Open the Part file through batch
Add the -retrieve option to pass the part file name to ugraf.exe.
CODE --> script
Using ugraf will cause a new instance on NX for each "Call".
Using just the part name will cause windows to use the default association for the .prt extension (ugs_router.exe) which will start NX if needed or reuse a running instance and pass the part file to NX.
CODE --> script
HTH, Joe
Where can I get these knid of batch arguments script info?.
Is anything mentioned in Documentation?
Selvaraj C
NX Automation Engineer.
The NX launch command line switches:
https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_help/#uid:launch_win_switches_r
"Home -> Fundamentals -> Launching NX -> Start NX on Windows Platform"
Ugs_router.exe switches:
https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_help/#uid:xid280878
"Home -> System administration - Command line utilities -> Start and connect to applications"
Also, using an NX command shell and entering the command ugs_router with no arguments will cause a popup dialog that describes all of the arguments / options.
HTH,
Joe
