CATIA V5R9 RUNTIME ERROR
hI,
I have runtime exeption error when i run v5r9 or v5r10
Somebody can help me
Thk
Thk
RE: CATIA V5R9 RUNTIME ERROR
You should create a different directory for every version CATIA. Is it the case ?
Pascal
Business Partner CATIA V4 & V5
but beginner in English language
plambert@rgb-technologie.fr
Yes and no, I try a version v5r9, i work with 20 minutes drawing part design after that runtime error.
I uninstall r9 and try a release of the v5r10 same problem. I try to open adutocad drawing with it, it open the catia desktop with drawing tool...runtime error.
I know i don't have a certified computer, i have
PIII 600
256mRam
20 gig hdisk
PowerColor XpertColor ati rage 128 32meg.
Win 2k
my hard disk have 4 partitions, maybe i don't have enought free space.
What i want is to expériment this version correctly with this pc if its possible.
I'm planning to by a IntelliStation M pro with Nvidia 980XGL or a Wildcats videocard.
A friend of mine are planing to by catia and a the resaler said that is not a obligation to by certified computer to work properly.
Thank for help!
http://www.catia.com/your_catia/html/hwnt2.htm
You should also have 2x ram in swap, that is 256x2 = 512Mo
256Mo a light, today adorned me, 512Mo is recommended
Pascal
your computers'date may be different from current date...
2. check for your hard format method..
recommand ; NFTS
The date is correct and the HD are in ntfs.
Maybe it is the ram or semething like that. Or the video card.
But thanks for your support!
A lilltle bit better, but my system crash after drafting and move the origine of the (viewer UCS).
RBTX
Now it better. but i have another problem wen i check the integrety i found this missing file CATSettingsDialog2.CATNls
Witch CATSettings i have to delete?
Thank
