What does 208/240V ratings mean for electric baseboard?
I wanted to inquire about the 208/240V ratings that are available in most electric baseboards. Does it mean that the baseboard is compatible for 1-phase, 208V as well as 1-phase 240V connection? And also that when connected to 1-phase, 208V the output wattage would be 25% lower than, when connected to 1-phase 240V?
Thank you.
Thank you.
RE: What does 208/240V ratings mean for electric baseboard?
CR
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
CR
Bill
"Why not the best?"
Jimmy Carter
CR
