Shouldn't the Tesla car be named Edison?
After all, it is a dc vehicle, no?
RE: Shouldn't the Tesla car be named Edison?
DC energy storage. But AC motors, afaik.
Gunnar Englund
www.gke.org
Why not the Watson?
Definitely AC motor and VFD, so definitely Tesla rather than Edison. Besides, if your thought is the batteries, Volta would be a better choice, no?
Sure it's computerized. But "THINK" Watson?
Are you thinking Westinghouse, perhaps?
Gunnar Englund
www.gke.org
Calling it the "George" would seem to be a better choice if that's the path to take.
Calling it a Westinghouse would bring up images of washing machines and refrigerators to us old geezers...
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Westinghouse brings up images of the electric chair.
Edison's assistant was named what?
Or why not the Morgan, after the person that financed both Edison and Tesla at one time or another.
Actually, contrary to popular belief, Tesla did not "invent" the AC induction motor per se, he just made one that was practical and patented it first. The first "inventor" of a working model was Galileo Ferraris, who published his papers just a few months before Tesla got his patent.
But if Elon Musk called his cars "Ferraris", he would have been in trouble from the outset...
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
OK, Ferraris published a paper some time before Tesla got a patent. That two guys think along the same path is not uncommon when the time is right. Tesla had probably been doing work for some time before applying for the patent. He started thinking about it already in school.
It was known and it was taught in schools that two sines with 90 degree phase difference create a circle in a Cartesian system and that the circle "runs in different directions depending on the phase shift being +90 or -90 degrees.
I would say that both guys invented the induction motor. Independently.
I'm not so sure if induction motors are used in the Tesla (I haven't got the one I ordered yet - even if I was very particular about the delivery date!). I ordered it under the assumption (sorry, Jeff) that it uses PM motors. If it doesn't, I will send it back.
Gunnar Englund
www.gke.org
http://my.teslamotors.com/roadster/technology/moto...
Definitely an AC motor, and the link above from Tesla i.e. the horse's mouth, calls the one in the roadster an "induction motor".
Does the model S have a permanent magnet AC motor rather than a true induction motor? I don't know, but if it does, it will likely also have a forced fluid cooling system on it because the PM motors are affected a lot by heat.
OK, I wonder if they will take it back on the grounds that I didn't read the specs?
Copper rotor keeps slip at a minimum. That is good. It also does away with the potentially dangerous situation with "forced" field weakening at higher speeds. Tesla seems to be doing the right things. And batteries are quickly getting better and cheaper. Graphene seems to be useful here, too.
Gunnar Englund
www.gke.org
I get go to the Tesla factory about once per quarter for one thing or another, it's a hoot. I wish I could afford one, they are one well put together vehicle. https://www.youtube.com/watch?v=8_lfxPI5ObM
And yes, they are AC induction motors and no, they are not iPM or sPM AC motors, they are basic induction motors, albeit custom made for this application.
Personally, I like AC/DC.
Mike McCann, PE, SE (WA)
msquared48: "Me and me mates loik AC/DC...Hot and sweaty, loud and greasy!"
Permanent magnet AC three phase motor.... beautiful combination with VFD in terms of efficiency.... quite a step forward from the standard AC induction motor...
A bit surprised to read the Tesla AC motors are in fact AC induction motors (on the link above).. The Toyota HSD system uses PM AC three phase motors..
There is one circumstance that may have influenced the choice, it is about field weakening.
The "overdrive" (5th and 6th gear) that makes cruising at high speed economical is easier and safer - almost automatic (increase f and keep U so that V/Hz is reduced) when you use an induction motor.
If you have a PM motor, you need to reduce the flux by forcing it down with the stator flux. That is not only wasteful, it is also dangerous because the slightest irregularity in the control will let the PM flux grow back to base speed flux. Imagine then, what happens to motor voltage when motor is running at twice or three times base speed.
Yes, it gets very high and kills (explodes) the inverter.
Therefore, the induction motor is a better choice. And if you use a Cu cage, the slip can be kept at very low values, so that efficiency is maintained.
Gunnar Englund
www.gke.org
I give up.
(I do know assistant's name for Alexander Graham Bell and for fictional detective Sherlock Holmes, but not for Edison).
(2B)+(2B)' ?
Edison had several "assistants." Hammer, Robbins Upton, Jehl (light bulb), and Dally (fluoroscope)
TTFN
Didn't Edison have Tesla as a consultant too? (Whom he screwed ROYALLY.)
Keith Cress
As an employee, yes. Edison hired Tesla when he first arrived in the US, and told him to improve the efficiency of his DC dynamo by a certain percentage (can't remember the details). Edison allegedly offered Tesla $50,000 if he could do it, apparently thinking it was impossible. But just a few months later, Tesla presented him with the improvements and test data, then asked for the money. Edison allegedly told him it was an offer made in jest, and said something to the effect of "you'll understand once you have become a full fledged American", at which Tesla promptly quit in contempt, an opinion they both held for each other thereafter. I think I read somewhere that right up to the end of his life, Tesla believed Edison still owed him that money.
Otherwise known as the Edison screw !
