A410S Stainless steel Category
I am confused with the category of ASTM A410S stainless steel. Whether this is coming under a martensitic category or ferritic category? And do I need to consider preheating while welding this to CS?
RE: A410S Stainless steel Category
(There is no overlap in C range between 410 and 410S)
This is called being careful.
"3.1.4 martensitic grade, n—metallurgical term meaning that
the material is capable of being produced in a distorted
body-centered cubic structure by conventional heat treating
and quenching, and that the quenched structure is capable of
conventional tempering. Martensitic grades are delivered in the
annealed (ferritic) condition or the hardened and tempered
(martensitic) condition."
So it may be ferritic or martensitic depnding on the heat treatment it undergoes, as per our demand??
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
